Stroker or
Username: Dontavious89
Laurens, SC USA
Post Number: 8
I'm about to by an spl sub,which is better ,stroker,juggernaut,RF's MT,or is there some other subwoofer that is the best.
yep
DD 9900's are good too.
i'd have to say the MT is the best out of the ones you listed.
a really unreal SPL sub would be the next RE XMX, it has 6 inches of oneway through!!!
check out the vid on realmofexcursion.com
its unreal!!!!!
