Bronze Member Username: ElecgeniusLa Puente, Ca United States Post Number: 96 Registered: Oct-04 | i was just wondering how credible is this. i kno glass told me soundstream was made by power accoustic but zac said its not. htey made SPL subs together and thats it. puttin that asside, how creddible is that amp thats able to take up to 21 volts of energy. what sub would be a good match.... http://www.soundstream.com/sub/products_amps_XXX.h tml http://www.soundstream.com/sub/products.html |
Gold Member Username: Jonathan_fGA USA Post Number: 2569 Registered: May-04 | They are owned by Power Acoustik, but from what I've heard they are free to manufacture and engineer their own stuff as long as they are profitable, basically. The newer stuff is still on the questionable side, they've gone down the tube lately and unless they truly come out with some great stuff like they used to, I'd steer clear. Haven't heard the subs, but I haven't heard anything really great about them from reviewers and such. As far as 6kw goes, you can use that amp if you want to, remember that thing will draw tons of current and you'd need HO alternators (note the plural tense) hooked in parallel to properly power that amp and other accessories at full draw. If I were putting 6kw on any type of subs, I'd probably get Eclipse Titanium Pros, 15" or 18", and put those on that amp. |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 5446 Registered: Dec-03 | http://www.zapco.com/prod/comp_prods/c2k4kwFrame.htm I believe USAmps offered a similar product as well. why do ya need anything with that much power in a single amp though? |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 5447 Registered: Dec-03 | oh, the term btw is "wholly owned subsidiary," I believe. It's similar to Acer owning Apoen or DCM owning McIntosh Labs. they're owned by, but don't share manufacturing facilities with their parent company. |
Gold Member Username: Jonathan_fGA USA Post Number: 2570 Registered: May-04 | Yep, the US amps USA-6000 produces 6000W RMS bridged into 2 ohms. http://www.usamps.com/default.asp?View=products/inv/usa-6000.htm Not only that, the amp is Class A/B, unlike the Soundstream which is Class D, so less distortion, absolutely huge damping, etc. Not that with 6000W RMS you're worried about the SQ. Being an AB amp that's 6000W RMS, the current draw would be a b*tch to supply, though. |
Bronze Member Username: ElecgeniusLa Puente, Ca United States Post Number: 99 Registered: Oct-04 | would that be enough for two 3*x 15's |
Gold Member Username: Its_bacon12Hfl, Ny Usa Post Number: 1051 Registered: Dec-03 | you're kidding right? that amp has 900 Amps worth of fuses on it... you'd need 3-4 300 amp alternators atleast... thats just rediculous |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 5451 Registered: Dec-03 | three fifteen inch whats? you could drive six fifteen inch triple X subs with that USAmps 6Kw job and still probably hve power to spare. |
