New member Username: Audio_paulWatkins, MN United States Post Number: 6 Registered: Oct-04 | Are these models good? Rockford Fosgate P312D4 Punch Stage 3 12" component subwoofer with dual 4-ohm voice coils. and Rockford Fosgate P312D2 Punch Stage 3 12" component subwoofer with dual 2-ohm voice coils should i get the 2 ohm or 4? its goin into this bandbass box..... http://www.crutchfield.com/S-E78i5wvL2mX/cgi-bin/ProdView.asp?g=178750&I=044QB21 24 |
New member Username: Dontavious89Laurens, SC USA Post Number: 5 Registered: Oct-04 | I heard these work ok sq subs,but if you want more bass go toward a Rockford Fosgate Punch HX2 RFD2112 ,or a Alpine SWS-1222D .And I wouldn't get a bandpass box If I were you I would get a ported or sealed box,sealed tend to get real loud(which is a good thing.Bandpass put out the really really low notes and take away a bunch of your db. |
