Help!!!!
Username: Morgan
I have got a componenet set of speakers and they are not the same size as the old ones that are already in my car. They wont fit. How can i make them fit? ive heard that you can make a new door panel or something that you can create so it can hold you new speakers? any website or something that teaches you how to do this? help! can i do this? what else could i do?
TMAc
Don't make a new door panel, make the hole bigger with an electric saw, the door panel is made of plastic and you wouldn't be able to make one.
TMAc
