JL or Audiobahn
JBfromCHS
Should i get 2 of the JL Audio w7 13's (really 13 1/2, which are 1000 rms each) or 2 Audiobahn AW1208T 12's (which are 1500 rms each). I know the Audiobahn have more rms but ive heard JL is better quality and I really like the JL's. And also, if i got the w7's, what would be a good amp??? Thanx in advance
Username: Chevy_for_life
Post Number: 144
JL is better than audiobahn find 2 1000 watt amps cuz if you find a 2000 watt amp its prolly gonna be pretty pricey
adsf
the JL is a much better sub. you could get a JL 1000/1, a KX1200.1, a JBL bp1200.1, or something like that to run it.
audiobahns are just a waste of cash.
how much SPL are you looking for here? because a single 13w7 in the right box can do ~150dB! and the JL's are very expensive (like $800 for a 13w7 retail).
you may wanna look at adire brahma's, Imaging Dynamics IDmax's, or RE X.X.X.'s. they are right up there w/ the JL w7's as far as quality, but nowhere near as expensive.
Username: Stanleyc
Post Number: 61
Audiobahns aren't even in the same class as the JL subs. Watt ratings don't mean anything if the subwoofer can't make good use of the power given to it. 1500watts on an audiobahn equals a lot of heat and crappy sound. When I mean crappy, I mean really really crappy. So bad, you'll be embarassed to even turn on your system with other people around.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4969
god what a question..
that's like asking if you should buy the McLaren, or get the riced ford escort.. heh
JL no question.
Look at the Xmax alone between the two.
you've comparing a $900 sub to a $40 sub here.
it's not much of a comparison.
JBofCHS
Ok, thanx, I knew you all would say JL becuase it is so much better, im just tryin to convince my friend that is like in love with the Audiobahns with 1500 rms (although he's never even heard them) that if he gets those and i get the 2 JL's my system will kick his system's butt. Haha i was goin wit JL all the way, just wanted to prove to my friend
Username: Zacdavis~
Post Number: 168
hey stanleyc, you've been misguided.
i've done a 153db on a termlab with two aw1208t subs, and yes they sounded great. pull up next to my car and we'll see who is embarassed. however i do agree jl has better build quality than audiobahn but as far as sq, neither are focal. they're street beatin subs, go with the aw1208t's, they're half the price of the 13's and they'll get plenty loud for you
Username: Stanleyc
Post Number: 67
Yea, personally I'm going to go with RE 12's. Just having a hard time find amps for them right now. =)
ThatGuyYouKnow
Witch RE 12's? iv got 2 SE's and thinking about 2 04KX600.1 amps (04 Kicker 600.1) perfect match of RMS and I want to do custom work on the shrouds of the amps.
Username: Glasswolf
Post Number: 4996
audiobahns can get loud, but they sound like a$$ doing it.
the W7 is by far a better SQ sub. Particularly at high excursion.
153 isn't bad, but I've seen a single W7 hit in the 148+ range, so it's still not saying much, and trust me.. the W7s will embarrass anything audiobahn makes, by a long shot.
Particularly when you start looking beyond mere SPL and start looking at SQ and reliability.
SPL isn't everything.
Username: Glasswolf
Post Number: 4997
the aw1208t has 18mm one-way Xmax, and less surface area than a 13W7 with it's 32mm Xmax.
You really think the audiobahns will be louder, huh?
keep in mind the "1500 watt" power handling of the aw1208t is strictly a thermal rating, too. It's a horribly inefficient speaker design, and requires far more power than it should for what it can really do.
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 140
I love you glass (not like that sicko)
Username: Glasswolf
Post Number: 5009
:P
Username: Zacdavis~
Post Number: 177
oh my god, lets stop this audiobahn battle, we all know they are an imported substandard brand. but, I WILL BUILD A SPL CAR WITH AUDIOBAHN SUBS AND KILL W7'S, i'll use 12"IMMORTAL QUAD COIL WOOFS, ANYONE WITH 12"W7'S IS WELCOME TO CHALENGE ME. PEOPLE CAN TALK ALL THE SH!T THEY WANT ABOUT #'S BUT I PUT THEM UP. i'm not a big jl fan as you can see
yes the jl has long a vc, but what good does that do when the motor is clearly undersized and it travels out of the gap anyways. W7's arent so great. neither jl or audiobahn make a sub that i'd jump up and down about. so lets drop the whole which one is better, duhh wahh.
and glass, bro, dude, friend, come on man, how many spl cars have you built using jl's and audiobahns? i've built dozens. like i said, i completing respect your opinion and acknowledge your vast amount of technical experiences in this field, but bro, i'm tellin ya the audiobahns will get louder than you know bro. also their spl5000 amp is no slouch either. you mentioned a 148w/ one w7 13, i've seen 160 with one immortal audiobahn. come on man...cut them some slack:-)
Username: Deathshadow
Post Number: 97
They sound like a wet f@rt while doing it though...
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1026
well if we're goin on numbers here, diamond audio hit 169 dB with ONE SINGLE 10 INCH sub
it all depends on the application you're using...SQ setup, a w7 will easily hit 145-148, let alone spl? or outlaw? hmmm...i wonder what a w7 could do outlaw ...oh the possibilities :-)
but zacdavis, given the same application, the w7 will obliderate any audiobahn throw to compete with it
Username: Glasswolf
Post Number: 5080
believe whatever you like.
there is no point in arguing with you about this.
you'll believe what you like regardless of the imperical data presented.
Username: Zacdavis~
Post Number: 178
agreed:-)
Username: Zacdavis~
Post Number: 179
but first just one last comment about this audiobahn thing and then lets drop this issue,
hey bacon, say what you want about which sub is louder, i've built and installed over 30 w'7 enclosers and many audiobahns as well. i build spl vehicles. i am the midwest regional champion, the wisconsin state champion in multiple classes, wisconsin state record holder, and at world finals in nov., i will be world champion, so maybe you shouldn't just shrugg off my "opinion" of what is loud, because i happen to know first hand waht is:-)
the loudest car i have built used two 9915 DigitalDesign quad2ohm subs and 8 spl3000d amps, i pulled consistent 167's on the termlab.
thats all, i just wanted to brag a little.
finally, never make your final judgment of somethin from what you read, i go by real world testing, hands on, know what i mean?
ok though, let this be the last post about how good audiobahn is, cause we all know they arent anywhere near the best, so since we all agree, lets kill it:-)
Username: Glasswolf
Post Number: 5083
just as a point of reference, Xmax for an Immortal 12" is 14.5mm.
Street price looks to be about $250-260 US for one.
From the psecs, it looks like it's designed to be competition for an Alpine type-R or similar, but it's certainly not going to beat an RE triple X, a Brahma, or even a 12W7, all of which have at least 28mm one-way of excursion, with equal surface area. It's a matter of physics. The sub won't be able to move as much air, which means it won't attain as high an SPL.
Where was this 160dB single 12" AB sub metered anyway?
was this outlaw class? was it on a termlabs mic?
what type of vehicle and enclosure?
Username: Zacdavis~
Post Number: 180
ab did a 170's with one 15, read all you want glass but i've used them all and i know whats loud, yes the re and brahma will displace more than the immortal but the jl is so underdampened its not even funny, i thought this thread was dead, lets start a new one under "one sub how loud"
Username: Glasswolf
Post Number: 5096
this thread is dead now. you just proved quite plainly that you know absolutely nothing at all about SPL.
you've just essentially disproved any credibility you may have had, with anyone.
"170s" (174) is the SPL world record at present in sanctioned events. It sure as hell wasn't done with a single fifteen from audiobahn with an 18mm Xmax.
When you learn a bit more about the real world of car audio, and not what you think you know from reading websites or hanging around some local Best Buy, come back and start posting.
Bye zac.
Username: Glasswolf
Post Number: 5097
By the way, good job avoiding every question I asked that related to validating your statements.
Do you know anything about SPL events or classes for sanctioned competitions?
"wow that's loud! my ears hurt!" doesn't mean it's automatically in the 170s.
Username: Zacdavis~
Post Number: 183
hey dumbf@ck, i'm an spl champion and record holder, where do get OFF tellin me i know nothing, your the guy that thinks xmaxx is the only thing that matters in spl. DUH...secondly your the idiot if your tryin to say that american bass didnt do a 170.1 with one 18"quad coil woofer, also team db warriors do consistent 174's with only two DD woofers http://www.termpro.com/asp/competitorstats.asp?Competitor_ID=22065&Season=2004
so wake up dude, this aint 1990's anymore, we're louder than you've ever been.
check my stats on www.soundoff.org, i hold more than one record and i'll be #1 in the world at usaci world finals.
you've really pizzed me off by discrediting my knowledge for the sport, go ahead and try to keep impressing all these ecoustics surfers while i'm proving the world that i have the loudest car in 901-1800 superstock and the loudest in 0-1000 pro stock.
get real glass, i cant beleive your talkin smack just because i'm louder than you, i mean sh!t, i'm not talkin crap about u just because your car is faster than mine
and 1 more thing
XMAXX MEANS NOTHIN IF THE WOOFER'S SUSPENSION AND MAGNET STREGNTH ARE NOT IN HARMONY.
OF AAAAAAAAAAALLLLLLL PEOPLE............YOU SHOULD KNOW THIS!!!!!!!!!!!!!!!!!!!!
Username: Zacdavis~
Post Number: 184
hey glass, to clear up somethin you misunderstood, i just realized that i said ab, i meant american bass, not audio bahn. now i see how u could think i was full of it, i know audiobahn wont bein doin a 170 with 1 sub anytime soon:-)
Username: Zacdavis~
Post Number: 185
but your still way to quick to judge bro, you obviously know nothin about me
Username: Boopers
Lima, Ohio United states
Post Number: 210
what's your name so i can look you up on that soundoff site?
Username: Zacdavis~
Post Number: 186
uhhhh, zac davis
Username: Zacdavis~
Post Number: 187
http://www.soundoff.org/2004finalsinvites.xls
Username: Boopers
Post Number: 212
C117196
that's your member number, I don't see you in the USACI State loudest SPL champions report or the Member stats, or the USAC winners list. Are your wins during this year or were they from years past? Just curious, thought I'd look you up in some of the catagories other than invite list.
Username: Zacdavis~
Post Number: 188
look under "state records" , i live in wisconsin
Username: Zacdavis~
Post Number: 189
i'm in the "member stats" page, look for my full name zachariah davis
Username: Boopers
Post Number: 214
nice, 7 events all 1st place, I take it that most that ransom's is the main competition place where you live 4 or 7 events there
Username: Zacdavis~
Post Number: 190
actually not all of the events have been uploaded to the site yet, i also competed in many unsanctioned events as well, all placing first.
but to answer your question i've had to drive at least two hours to get to shows and owning a small custom shop i'm busy so makin it to shows is kinda hard
i cant wait for world finals
yes, ransom has a few locations and they always put up great shows, if you want i can show you a pic of me in my explorer at a smaller show, i didnt bring the crx to that one.
http://www.termpro.com/asp/eventresults4.asp?Event_ID=6815&StartPage=0
Username: Glasswolf
Post Number: 5099
actually you claimed 170s with a single fifteen.
Then you changed brands and sub sizes.
Being able to pay installers or "own" a company doesn't mean you know anything about the physics of car audio though, or what does or doesn't work.
I've known plenty of shop owners who make decent money, and don't know an amplifier from a jar of jam.
I'm curious to know what certifications and degrees you hold related to this field as an installer?
Username: Zacdavis~
Post Number: 191
i didnt change brands, your the idiot who doesnt recognise the abreviation "AB", it stants for american bass, not audiobahn, its not my fault you dont know the difference.
and hey dumb@ss, i've been an installer for 11 years, and guess what, i'm still installing fulltime, i only have one part time installer.
what the hell is your problem, are you pissed because there is someone else on this forum that knows a thing or two besides you?
get off your soapbox assh0le.
i'm the one breakin his back everyday doin remote starts, alarms, installin radios, and all the other car audio related sh!t. i've been installing hydraulics for 10 years as well. and yes we at Porkys hydraulics broke the world record in the two pump class. i learned from the best. and now i'm one of them. see thats the difference between you and i. if there is somethin to learn i listen, unlike you who just wants to be a know it all.
you must be the biggest loser to just sit on the internet and diss on people, i never dissed you so why u makin me a target, are you havin a bad day or what?
Username: Glasswolf
Post Number: 5111
No, the actual reality is you just can't admit when you're wrong, like you have been throughout this thread. Go back to installing for best buy where you belong.
I have no problem with people who really do know what they're talking about, and I can name several on this board. You're not one of them, and all I see you do is offer people misinformation and misguided opinions.
Do whatever you like. I really don't care.
when you grow a pair, and get tired of name calling on the internet, let me know.
Hfl, Ny Usa
Post Number: 1033
oh man zacdavis, you got compuserved!!
haha had to be said
g-dubya, you're my hero
Username: Glasswolf
Post Number: 5122
I'll put an end to this by saying that I've been of very short, and ill temper the last couple weeks.
I've been dealing with both personal illness and a death in the family, so I've been in a pretty sour mood.
I apologize here and now for dragging this on as long as I have.
I'll be polite at this point and step out of this, and leave any final thoughts to Zac.
see ya in the other threads.
no hard feelings I hope.
on another note, you're just across the lake there in WI. When I finish rebuilding the car this winter, I'll try to hop the Ferry across and perhaps hit a few events over your way. Maybe we can meet up some time and grab a drink.
Username: Zacdavis~
Post Number: 192
and what is it i'm wrong about?....
#1 ab did do a 170 with one woofer, your wrong
#2 i backed up my competition history, your wrong
#3 so what is it i'm wrong about
your the one who got served, damn, your so dense you cant even see it. and nor can your cronies. btw, my shop is called Tinkertoy Customs, I sell US Amps, Digital Designs, Aphasonic, Kove, MMats, MTX, all Godfather Customs products, Airride Technologies and Porkys Hydraulics and many others. i dont need to prove to some kids on this forum that i've got skills, all my customers know i'm qualified:-)
hey bacon who got burned?
re-read the posts
Username: Zacdavis~
Post Number: 193
oh, i'm sorry to hear that, i just read your last post, i understand now, i thought those posts were a bit out of character for you.
well i look forward to meeting you next season then, we need all the sq guys we can get, i dont believe i've ever seen a mopar sq car. people will love it:-) i'll buy ya a drink anytime
Username: Zacdavis~
Post Number: 194
but for the record, i've never given anyone misguided information, and i've had my pair for 28 years. the more i read glasses appology i realized he never stated what it was exactly i was wrong about, that, i'm still a little confused about. oh well.
i think that maybe glass isnt used to people disagreeing with him, and its understandable, he has many notches in his belt and deservingly, when i disagreed with him it may have been talken personaly against his intellect, but i never meant that in any way, i may not be have been around as long as glass but just because i'm new on this block doesnt mean i havent been around. like i said in previous posts, i shouldnt give advice on which brand is better, because it always leads to this, however i will still help anyone with tech ?'s they might have, car audio has paid my bills for 11 years, i've picked up a bit of knowledge myself. and no it wasnt from best buy, lol. anyways, anywhere from diod isolating resisters on one wire keyless entry systems to tuning your sub box...i can help, and if glass or jon or sean or anyone else hasnt answered your question already, i will.
so come on guys, give me some props
Username: Stanleyc
Post Number: 85
Here you go. *hands a prop over* LOL
Good to hear all is well again. =) And yes, we need as many informed people as we can get here.
Username: Zacdavis~
Post Number: 209
http://www.12volt.com/archives/archive_files/2000_archives/us110100.html
who says they suck?
Username: Glasswolf
Post Number: 5351
I do.
we're talking about the hooters girls, right?
Hfl, Ny Usa
Post Number: 1041
lmfao....
"power and reliability of audiobahn"
*grins*
Username: Zacdavis~
Post Number: 217
hehe
lmfao,what does it mean?
ROFLMFAO hehe
laugh my fukcing a(_!_) off??
Username: Lbeckner
Tulsa, Ok Usa
don't misguide this poor guy!!!! The audiobahns are FAR better than the JL's. Go with the Audiobahn man! Everyone will love you!!
AudioDouche
Post #51 just 49 left to go!
Username: Jonathan_f
GA USA
Post Number: 2527
Lucas, I hope you're joking.
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 241
yeah, really.
JL over audiobahn.
Username: Lbeckner
Tulsa, Ok Usa
yeah. i was being very sarcastic.
GA USA
Post Number: 2535
Just had to clarify :-).
