Pre-drilling holes in box
Username: Thumprms
DaltonUSA
Post Number: 51
do i pre drill through the first piece of wood and through half of the second piece of wood? then drill the screw in?
Username: Pat_l
Tucson, AZ USA
Post Number: 700
you can if you want but usually its not that big of a deal. The only thing w/ pre drill is if the sub shifts while drilling you holes could be off. Plus there is that much more of a chance the drill slips and you punch a hole in the thing. Not a big deal.
