JBL 1200.1
Username: Ampman
Bradenton, Florida U.S.A.
I'm thinking of getting the JBL 1200.1. Its rated 1200 at 2 ohms. My speakers are the 8122 Eclipse. I believe they are single voice coil 4 ohms at 450 rms a piece. Is there any way to get these two subs wired to 2 ohms for this amp?
Username: Audiobahn_man
Freakmont, MI
Post Number: 249
not if it is single voice coil....if you have 2 of them you can wire it to them for a 2 ohm load. it is a 1 channel amp but has 2 + and 2 - so you dont have to wire one sub to the other, it does it by itself.
Username: Ampman
I have two. I just found out how I can do it. Thanks
Freakmont, MI
Post Number: 251
np
