Anybody got any opinions on bazooka?post your opinions
josh burges
What's does everyone think of Bazooka Amps And 10" And 12' subwoofers, especially amps.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5054
like sony, power acoustik, and audiobahn.
cheap junk, poorly made, and with fairly high failure rates.
Username: Bumpingloud
Phoenix, AZ USA
I've installed bazooka amps. And Alot of people come back saying it over heats too much in like 10 minutes of playing. All you have to do is install a cooling fan. But I still wouldnt buy any of their products.
Username: Insearchofbass
Post Number: 961
poor sound from subwoofers and their amps die on you
Username: Ctx
Post Number: 84
there tubes sound good if your in a small truck I had one but it crapped out on me
davidryder
haha i had a bazooka bass tube with a built-in amp, it sucks becuase there is no remote and at low levels the bass cuts out. i don't know, i think the tube is just crap overall
Username: Igotpenguinz
Mi
Post Number: 19
I had a 600 watt bazooka running 2 10's rockford he2s I think? didn't sound bad and its still running. If your thinking about getting any bigger i wouldn't recommend bazooka to anyone. If your looking for a system thats cheap for your girlfriend to bump then go for it.
