Question for Glass on refurbs
Username: Thumprms
DaltonUSA
Post Number: 45
car domain has a JBL BP-600.1Z which is perfect for pushing the sub i want. the only problem is is that it is a refurb. here's the link http://www.cardomain.com/item/JBLBP6001Z
would you recommend buying it?
Username: Audiobahn_man
Freakmont, MI
Post Number: 231
I would...I bought my JBL 600.1 that was used for almost a year and it works fine.
Username: Koz1031
Monticello, In United states
Post Number: 237
You get everything but the birthing sheet. Even a 1 yr. warranty. I'd go for it if I needed an amp.
Username: Thumprms
DaltonUSA
Post Number: 47
Glass does the JBL BP-600.1Z have an infrasonic filter?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5247
nope.
FMOD makes one you can add for about $20 from partsexpress.com
20Hz high pass RCA level
Username: Thumprms
DaltonUSA
Post Number: 48
ok thanks
what does it do exactly?
Username: Glasswolf
Post Number: 5253
if you're using a ported box, you need to block frequencies about an octave below the tuned port frequency to prevent loss of suspension for the sub, and subsequent damage to the speaker.
sealed boxes don't need the filter. they don't lose suspension.
Username: Boopers
Lima, Ohio United states
Post Number: 223
it's 29.50 for the fmods glasswolf
Username: Boopers
Post Number: 224
gah, er 25.90 sheesh I'm scatterbrained today
