Please post, what amp for my alpine subs *Help Please*
Username: Rob36
Post Number: 10
I have 2 12" SWR 1241 alpine type R subs. Can I get a recomendation or two for what amp to get to power them? thank you...
specs for each sub:
Power Handling: 1000 WATTS /300 WATTS RMS
Frequency Response Fs-1kHz
Sensitivity 87db
D.C. Coil Resistance (RE) 3.6
Inductaance (LE) 1kHz/20kHz 2.38mH/ 0.85mH
Free Air Resonance (Fs) 26Hz
Equivalent Stiffness (Vas) 66L
Qms/Qes/Qts 10.39/0.38/0.37
X max/ X peak 12.9mm/ 25.8mm
Mechanical Excursion (P-P) 55mm
12" Dual Voice Coils
Diaphragm Material Kevlar Reinforced Pulp
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5216
JBL BP600.1
Username: Rob36
Post Number: 11
so i need two of those then?....
Username: Glasswolf
Post Number: 5221
just one.
Username: Glasswolf
Post Number: 5222
btw, ww.cardomain.com has them on sale right now.
very cheaply, too.
Username: Rob36
Post Number: 12
actually which is better 4ohm subs or two ohm
basically the 1241 type r or the 1221 type r
Username: Glasswolf
Post Number: 5240
if you have two subs, and a monoblock amp, you'll want single 4 ohm coil, or dual 2 ohm coil subs.
It depends on which is offered.
I think the type R comes in single 4 ohm.
