Where to find 4"x6" 8 ohm speakers
Farmer
8 ohm is OEM for a piece of equipment of mine. Are they available anywhere? All I can find is 4 ohm. I'd like to keep it original without going the autoformer route. Thanks.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 5120
won't have much luck there.
unless you go with a factory replacement speaker from a dealer.
Farmer
This was the premium sound system in Allis Chalmers combines in the early '70s'. OEM hasn't been available for a LONG time (I can see why). Thanks for the reply.
Username: Glasswolf
Post Number: 5130
some GM factory speakers are 10 ohms.
That'll be a fairly close match.
You could probably try using LPads to attenuate the signal to a set of 4 ohm 4x6 plates as well, which may work out for you since an Lpad circuit adds impedance to the circuit path.
http://www.bcae1.com/lpad.htm
Farmer
The Lpad concept is new to me, but looks like it may be the way to go. That website does a nice job of explaining/discussing it. Thanks!
