Which sub for me
Username: Hifonics
Post Number: 52
ok i have the hifonicz 1500d and i was wondering which subs no matter how much it counts besidez the re xx.x,i could get. I would get the xx.x but im trying to outbeat my brother which a x.x.x in a 3.5 cu ft. ported box. OH yea and the box vloume 4 me is 4 cu ft. repli plz
Username: Boopers
Lima, Ohio United states
Post Number: 208
good luck getting a better speaker than re 3X. You could outdo him spl wise with the same speaker. What kind of car does he have, what size sub, what size amp? What car do you have?
Username: Hifonics
Post Number: 53
both of us have impalaz i have the 04' he has the 01'. he has a 3000watt ultralinear capable of 1200 watt rms. he has the 12" version. He has 100watt rms going to the sub n a 3.5 so its not at its poteial i think. BUt what about 2 matix's or eclipse titanium or 2 dd 3500's which i have now but never installed them
Username: Zacdavis~
Post Number: 181
the dd's will be louder than one x x x with 1500watts
Username: Boopers
Post Number: 209
if you went with a 15" 3X you'd outdo him. As for the eclipse ti's I don't believe they are as loud as the 3X. The DD's I don't know about at all, so maybe someone else with experience would be able to let you know about those. You could go with 2 12" brahmas but the only problem with those is there is a long wait for them. My experience is rather limited because I am fairly new to the car stereo hobby.
Username: Hifonics
Post Number: 54
so u sure zac becuz i have them now and ill b havin them .4 cu ft 2 small each sub
Username: Boopers
Post Number: 211
you can make up the cu ft difference with polyfill easily if it's only .4. if you already have those subs, use them. If they don't outdo his 3x then you can always upgrade. Use what you have.
Username: Slap_johnson
Arizona
Post Number: 83
the dd 9512 or 9912 will be louder, u could go 15" brahma
Username: Matt77
OK US
Post Number: 28
do u know what ur bros DB rating is
Arizona
Post Number: 84
or what you could do is get the exact same sub and enclosure and dynamat your car and you should beat him, or u could tune ur box a bit higher, OR if ur nuts and sq isnt involved u could go mt
Username: Hifonics
Post Number: 55
i would go 15" brahma ubut they have a long waitin list i dont know mah bros db rating i dont think it is that high do to the fact that he made his box in like 30 minutes. But i say its pretty high becuz when he parks inside the gate in our houz u will feel the bars shakin. BUt thanx for the repliz but ne estimation of what i would hit wit the 3 dd subs
