Need slot ported box for brahma mkII 12"
Username: Boopers
Lima, Ohio United states
Post Number: 197
would someone be able to come up with the external dimensions of a box for me if I give you the net volume needed, the displacement of the sub, and the desired tuning freq?
if so: 3ft^3 net, .15 ft^3 sub displacement, and 35hz tune
need to keep the height of the box under 15.5", that's the only restriction I have really
Username: Boopers
Post Number: 198
the box I designed in WinISD gave crap results
at max amp output *guessing 2400watts* at 1 meter I get these db results.
Driver : brahma 12
Vas : 38.0
Qts : 0.43
Fs : 28.00
SPL : 84.40
Project by : jeremie boop
Project for : you
Number of drivers : 1
Box type : Vented
Box size : 3.000 ft^3
Tuning frequency : 35.00 Hz
Vent : 1 vent(s)
13.20 in length for each
2.00 x 13.00 in rectangle
Freq SPL
[Hz] [dB]
20.00 101.35
25.00 109.62
30.00 117.35
35.00 123.32
40.00 123.58
45.00 121.99
50.00 120.85
55.00 120.12
60.00 119.64
65.00 119.31
70.00 119.08
75.00 118.92
80.00 118.79
85.00 118.70
90.00 118.62
95.00 118.56
100.00 118.52
Username: Insearchofbass
Post Number: 943
did you have port whistle? Id bet you did if you were pushin 1200 rms. Which would work against you as well for spl. Do a slot port 13 inch by 4 inch and make it 30 inches deep for a 35 hz tune youll need to make your ports have turns to accomodate the length
Post Number: 944
and youll have to account for displacement lost because of the port again
Username: Boopers
Post Number: 203
rofl, that's what I need to know, you got the port measurements, now I need the external box measurements.
Post Number: 948
15 h x 26.75 w x 23 d = 3.00 cf after displacements external measurements
Post Number: 949
that includes port displacement and subwoofer displacement
Post Number: 950
using .75 mdf
Username: Boopers
Post Number: 204
sweet, little deeper than I'd like, but maybe I can tweak the w and d a bit. got the brahma for 270, 322 with shipping. hopefully it'll be here beginning of next week. probably get here when my shocker gets fixed.
Post Number: 953
ill warn you now dont go with a smaller port if you definately dont want port whistle but its up to you
Post Number: 954
dont forget to account for the turns which changes the ports length needed for the desired tuning
heres the link you can use to understand how all this is done copy the link and paste in address bar and it will work
http://forum.sounddomain.com/forum/ultimatebb.cgi?ubb=get_topic;f=11;t=060743
