What speakers fit into a 1998 Ford Explorer XLT
Username: C11marks
I was trying to figure out what door speakers are in my 1998 Ford Explorer XLT so i can replace them. Does anyone know what size fits without a braket???
Thanks
Chris
Username: Sas
Post Number: 19
most fords have 5x7's speakers all around, you may also find a 8 inch sub on the drivers side in the back. make sure you dont have any stock amps and or premium sound systems. if you do you may have to bypass the amp for the speakers to work. to do this you have to run a wire from the head unit to the speakers.
what speakers fit 1993 ford tempo?
william henry
what size speakers fit in a 1991 ford explorer sport? so i can buy new ones. Thanks, Bill.
