Orange white lighting terminal
Username: L25
What is the orange white lighting terminal wire for on my P860MP. I assume its a dimmer.
I pulled the existing DEH P6000 and the orange white wires were not connected?
thanks,
jeff
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4967
not always needed.
it just dims the display when your lights are on if I recall.
not a big deal.
Username: L25
Post Number: 7
Dims the CD display when the interior dome lights are on?
I was wondering if some how the speedo/instrument dimmer knob would also dimm the CD display?
Couldn't find anything in the manual.
thanks,
Jeff
Username: Glasswolf
Post Number: 4983
headlights, not dome light.
RTFM maybe?
Username: L25
Post Number: 8
My understanding is that "RTFM" is particularly nasty remark reserved for true a**ho*es and imbeciles. ...Or maybe your reply was an innocuous suggestion? however, I prefaced my previous post with the fact that I did RTFM. Granted I may have overlooked the pertinent information, so I have looked it over a few more times. Still I find nothing. I installed it without connecting that wire.
Cheers,
Username: Glasswolf
Post Number: 5034
do the lights on the display work?
if so, the wire really isn't needed.
Username: L25
Post Number: 9
Yeah, it works.
Username: Glasswolf
Post Number: 5057
only reason you'd need the dimmer wire is if that display is too bright at night, and you find it distracting while driving.
otherwise, you're good to go.
