Sub enclosure
I have 2 8" subs and a 12", I want to put all three in the same enclosure. If I can I want to put the 12" in between the 2 8". If this is possible would it be better to have a vented enclosure, or sealed or what. I'm quite new at this car audio thing, please help me out.
Username: Pat_l
Tucson, AZ USA
Post Number: 689
I wouldnt go with mixed subs, Mixed brands just dont mix and mixed sizes also dont mix. Even if you seperate the box. I wouldnt recomend. A 12" sub will hit slower than a 8". Not a good idea, crappy sound. It would also help to find what is right for you, what is your music taste?
