Like
Explain Polyfill
guest
Can someone please explain the theory and effectiveness of using polyfill in a box and how one would go about doing it correctly? Any special conditions that would not allow the use of it? Does it pose a big dif?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4837
polyfill essentially slows soundwaves giving the impression that the box is about 10% larger tahn it actaully is to the subs.
It also reduces standing wave reflection which cancels waves and reduces output.
you want to use about 1 pound of polyfill for every cubic foot of box volume in a sealed box.
for vented, use rolled polyfill sheets and staple gun it to the box to line the box with it about 1" thick.
Username: Decde
Post Number: 150
When u buy a box already built, does it already have polyfill, or expanding foam, or anything that does the above???
Username: Glasswolf
Post Number: 4843
some have polyfill lining.
most don't
Username: Deathshadow
Post Number: 41
So should you use polyfill? Can you even notice the difference? hmmm polyfill is what they stuff pillows with... right lol?
Username: Glasswolf
Post Number: 4861
yes it is.
yes its noticeable. any time you change box volume 10% you'll notice.
worth it is up to you
Username: Followyoursole
Post Number: 34
can you go over board? Im currently using about 2 and a half pounds in my ported box right now....SOunds better then without, but whats a good amount? If i reduce it to 2 pounds straight will spl improve?
Username: Glasswolf
Post Number: 4884
rule of thumb is one pount per sq foot of box volume
Post Number: 52
just staple an inch layer around the top, bottom, and sides of the box and thats it? Can it damage your subs?
Facebook
Shop Related Deals
Directory
