Ported requires less power?
Username: Thumprms
DaltonUSA
Post Number: 35
if i had a sub that could handle 500 watts rms but i only gave it 320 rms mono. would that damage the sub by underpowering it?
you can run a 500wrms sub w/ 320wrms. just be carful and dont clip the amp. you will be just fine if you dont clip the amp.
Username: Insearchofbass
Post Number: 912
and if you wanted to make your power handling effectively less but more efficient with your 320 rms going with a large enclosure will help you too
Post Number: 913
and just as a side note ported boxes are more efficient with power than sealed
Username: Johnnylemoine
LaPlace, Louisiana United States
Post Number: 187
what is clipping an amp exactly?
Username: Fishy
Tamarac, FL USA
Post Number: 588
Clipping occurs when you push an amp beyond its limits. It can't provide enough voltage and "clips" the top(and bottom) off the otherwise sinusoidal signal making it resemble a square wave.
Not good for drivers as the cone actually stops moving for a while at peak excursion which can lead to the voice coil heating up enough to fail.
Plus it just plain sounds nasty.
-Fishy
Post Number: 196
thanks Fishy, maybe you can tell me something on my Inverted subwoofer thread.
