Will an IDmax 12" be OK in a 1.5 cuft ported box? (net volume)
dave-o
i only have room to build a box for my 12" idmax that will be 1.5cu ft after port and sub displacement. It says on the ID site that it should be used in a minimal of a 1.8cu ft vented box. But will it be ok to put it in the 1.5 cu ft vented box that i have the room for?
Username: Boopers
Lima, Ohio United states
Post Number: 192
you could make up the difference somewhat with polyfill. that would help
Username: Insearchofbass
Post Number: 934
two inches of insulation and your there 1.80 cf
