Changer with a stock head unit
Username: Jetteson
I have a 2000 Jetta and it has a factory connector for a cd changer. I keep looking around and I have not found a changer that I can just hook up to the stereo and use it like a factory changer. I feel like the only option I have is to go the the dealer and give them the $400.00 they want for a factory changer. Do you guys have any suggestions?
Username: Glasswolf
Post Number: 1361
try www.pac-audio.com
if they or metra don't offer ana dapter for an aftermarket unit, then you're stuck with ebay or the dealer for a factory changer, or get a good head unit with changer controls, like an alpine, and go all aftermarket.
Username: Jetteson
Thanks for your response. I have been looking on the internet for something like this and I ran across one company that does it. www.neocaraudio.com
Have you heard of them? They want like $250.00 for the changer and they said it will work just like the factory changer and it will work with the buttons on the stereo. What do you think?
