Port in relation to volume of box
Username: Thumprms
DaltonUSA
Post Number: 36
if the specs say 2.0 cu ft box with a 4'' port thats 10.75'' long. does that mean i can build a box thats 2.0 cu ft and add the port. or do i have to take in consideration the amout of volume to port will take up and make the box a little larger than 2.0 cu ft?
Username: Insearchofbass
Post Number: 914
the port does take up box volume so yes you would add that to your overall desired box size internal
Post Number: 915
the amount taken up is very small though
Username: Thumprms
DaltonUSA
Post Number: 37
so do you think i should build my box bigger or leave it at 2.o cu ft?
Post Number: 922
actually yes they prob accounted for the port
Post Number: 923
build it at 2.00 cf in other words
Username: Jonathan_f
GA USA
Post Number: 2394
Most manufacturers that recommend port size along with box volume are giving a gross volume to build. Basically, build a 2 cu ft gross box and put the port and sub in.
