Anonymous | http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729085228 &tc=photo OR http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729083833 &tc=photo |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 5427 Registered: Dec-03 | for a single Shiva? that KX600.1 is plenty the e1400 is overkill. |
Anonymous | Thanks for reply glass! Why is it overkill? It's Rated Power: 240 W RMS x 1 @ 4 ohm (12.5V); I found few other: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729235351 &tc=photo http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729467911 &tc=photo http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729235113 &tc=photo http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5729467948 &tc=photo I'm thinking memphis would be right but i'd like to see your opinion |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 5437 Registered: Dec-03 | oh yeah I was thinking of another amp. I just saw the header for the amp model, because on dialup it takes forever to keep loading ebay pages. anyway for a shiva anything up to 650 watts x 1 @ 4 ohms is fine for that sub. 1200w x 1 @ 2 ohms if ya want to run a pair of them they don't need that much but they'll take it. minimum I'd go 300 watts each for them memphis amps are good. so are the kicker and JL ones you listed. any of the bunch should be a good choice. |
