Don't really know what happened.......
Username: Smhuosrktays
Rochester, New York USA
Post Number: 17
THe other day I was driving around playing music, then went to Dennys, I came out to turn my music back on, and my DVD player(what I use to play CD's and DVS's) stopped working. It would only work when I held down the reset button. So I took out my DVD player, my in dash monitor and replaced it with my old HU.
Now, my old HU has been refurbished(I spilled pop on it, but it worked when I got it back). But after sitting in my basement for a few months it doesn't work, I checked the fuse for the radio, the fuse on the cd player(neither are blown). Does anyone have any idea as to why it won't work?
ps- i have already thought that my old HU might not work anymore.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6125
check voltages at the wiring harness in the car using a DMM
Post Number: 19
What a DMM and how would I go about checking these voltages?
Is a DMM one of those things where you can check the voltage that the battery puts out?
Post Number: 20
Forget the whole post, I figured out what it was, I blew some other random fuse.
Username: Katami
Albertville, Alabama USA
a dmm is a digital multi meter
Username: Glasswolf
Post Number: 6138
I find it hard to believe people can even install a system without having a DMM handy and knowing how to use one to be honest.
Even finding a reliable ground point is easier using a DMM.
Glad ya found the problem though.
