Help, i got 2x 6 ohm sub from stero system...
Username: Lighting_boy
i got 1 pioneer 3600 cd player, and a lighting 2 channel 45o watt amp the sub it 165 watt each, and 6ohm im wondering if there is any way that i can hook those sub up with my system thx
Username: Insearchofbass
Post Number: 904
if these are 6 ohm subs you would have to wire them for 12 ohms because your amp is more than likely only 4 ohms stable bridged
god.. just figure how to reply...
so i need to wire them like they r 12 ohm?, my amp is 4 ohm briged, they r hooking to 2x 220 watt pioneer speakers.
can i hook they to my cd palyer since it can power small subs. and im real confused with ohm ratings, the bigg the number, the better or smaller better?
