1100wrms amp, what size inline fuse
Username: Boopers
Lima, Ohio United states
Post Number: 79
what amp fuse should I get for the power wire
Username: Insearchofbass
Post Number: 554
whatever size fuse is recommended for the amplifier
Username: Boopers
Post Number: 80
also, I currently have 8 gauge wiring in my car, but they are all less then 6 feet in length, how much of an effect will this have on the amps output, since the website that dictates the wire gauge for power levels says I should have 4 gauge wiring?
Post Number: 577
heres a very good site for you to see the results with that wire vs other wire
http://www.bcae1.com/wire.htm
Username: Donp
Detroit, MI USA
Post Number: 14
8 gauge is a little thin even for a 6 foot run. You should consider another run of 8 or thicker.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4607
fuse will be 100-115A
you'll need a minimum of 4AWG cable for that.
http://www.the12volt.com/info/recwirsz.asp
