Bridging my amp for subs. May be a dumb question, but oh well.
Username: Invain
Michigan United States
Post Number: 248
Ok, supposedly my crappy 100x4 watt amp is not bridgeable, but I was wondering what exactly would happen if I did bridge 2 channels on each side so I have 200x2? I doesn't say it's bridgeable, but I am really curious why it isn't, because I don't see many that aren't, and what would happen if I did bridge it?
you could try it some times it just wont work and somtimes it just blows your amp and some times it sounds like crap
Username: Invain
Post Number: 253
OK. Thanks.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4502
you'd fry the amp, yes.
when you bridge an amp, you invert the signal on one of a pair of channels, so the sine wave is reversed for one channel of the pair.
this has to be done by pushing in a button, or flipping a switch.
if you can't invert a channel, you can't bridge teh amp.
if you join two channels (left front and rear) together on one speaker, you'll short out the amplifier.
more on bridging:
http://www.bcae1.com/bridging.htm
Username: Audiobahn_man
Freakmont, MI
Post Number: 170
I have a sony 1200watt amp is it bridgeable?
http://www.xplodsony.com/products/?CATEGORY=Amp/EQ&MD=XM-2200GTX
Username: Glasswolf
Post Number: 4509
its not 1200 watts, just to be clear.
that's peak rating.
real RMS is:
"200W x 2 RMS into 4 ohms"
"Speaker impedance -- 2 - 8 ohms (stereo)
Speaker impedance -- 4 - 8 ohms (when used as a bridging amplifier)"
yes it supports bridged mode.
it'd put out 800 watts RMS @ 4 ohms bridged, theoretically.
actually, closer to 600 watts RMS, since you lose some power to heat and inefficiency when decreasing impedance.
Username: Insearchofbass
Post Number: 870
500W x 1 RMS into 4 ohms, 20Hz - 20kHz @ 0.15% THD
yes
Post Number: 871
i copies from his link he gave and again i post the same time as you glass
Username: Glasswolf
Post Number: 4515
ah ok I just skimmed the page. I didn't see the bridged output rating.
hey my guess was close though! hehe
Freakmont, MI
Post Number: 171
ok, so would it run at 2 omhs bridged?? should i try it?I wouold be running 2 v-max 12''s off it in a 4.7 cubic foot box tuned to 32 Hz?How would i wire it?
Username: Glasswolf
Post Number: 4536
no.
if it's stable to 2 ohms stereo, it'll see half that load bridged, so only stable to 4 ohms.
2 ohms bridged is like 1 ohm stereo
Freakmont, MI
Post Number: 173
yea, i ran it at 1 ohm with my audiobahns and it got so hot after 5 min ya couldnt touch it so i wont bridge it
