Have a complete system, still hungry for more,epicenter or not
Username: Elecgenius
La Puente, Ca United States
i need some serious help. i got (1)1900 kole series, 540 mtx thunder, (2)aw1200t audiobahn-1100 rms inverted, (4) 6 1/2 component mb-quarts m series, (2) 6x9 mb-quart 2 way m series, pionner p7600mp, thinking of getting an epicenter audio control. i also wanna get a 540 to each coil on the at1206t's. put the amps on half. wanna get a hifonics for highs instead of the mtx. should i go ported box. i hate the subs inside out and inverted polarity. help plzzzzzzzzzz
Username: Mike_anthes
Canton, SD USA
Post Number: 47
well what do ya want more of...bass?...treble? how much $ do ya got to spend on everything?...i can garantee that those subs arent loud enough...
i can spend maybe 1200 more. i just wanna spend on bass. my treble is perfect right now with those mb quarts. they never recommend ported boxes. my system bumps though. u can hear it moe than a black away and my only competition as of right now are suv's. plz help. dunno if getting an amp per coil will do---box-----class d amp
Username: Audiobahn_man
Freakmont, MI
Post Number: 172
Im guessing with 1200$, your could get 2 12'' brahmas, and a jl 1200.1, that would blow those audiobahns out the window....
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4534
pioneer, MB quart, MTX all good.
kole and audiobahn are junk.
I'd suggest getting some better made gear there instead of trying to compensate by using an audiocontrol epicenter.
that's my suggestion for what it's worth.
get a good pair of high excursion subs, and a good solid amp that delivers a lot of RMS power and you'll feel a much bigger difference.
Post Number: 8
thanx again glass--- i had heard the 1206t's gave cleaner bass than the l7's so i went ahead and got those. i mean i think i got them cheap, like 120 a piece. maybe i got ripped off, but i got the registration and everything is legit. i think for 120 dollar subs and 140 dolla amps theyre alright
Post Number: 9
one more ting- i kno the l'7 suck,,, i was comparing them by the price and the quality.
Username: Glasswolf
Post Number: 4538
for $120 you could get a 12" adire shiva.
excellent sub. needs about 300-500wRMS to get full performance.
worth a look anyway
www.adireaudio.com
a single 600-1000 watt RMS class D amp (mono) will drive two of those very well, and can be picked up for $300-400 for a very nice one
Post Number: 10
thanx, i guess ill upgrade to two 1000 rms amps-im thinking hifonics, so when i upgrade my subs ill be ready to go, and yes, i kno not to put the 2 1000 rms amps all the way up. thanx for the help glass
jerryanderson
Hey isn't the 15L7 around...450$ or am i way wrong???
Post Number: 13
man if i had the money, i would get that 33"- or 03" inch sub. lol.
Post Number: 15
man, if i had the money, i would get the 30" or 33"???? subs.lol.
Username: Glasswolf
Post Number: 4551
problem with those large subs is they're sloppy, and have low Xmax.
just lots of surface area and a low Fs
you'd be better off using the same airspace for multiple 12" or 15" subs.
Post Number: 23
CANT ARGUE WITH A PRO---THANX
