Kenwood db plus subs
Juggalo Jeff
hey ya'll what do u think about these subs are they pretty decent
Username: Slap_johnson
Arizona
Post Number: 71
no, kicker CVR, V-Max
Juggalo Jeff
yyyyyy i kno bout cvrs whats wrong with tha kenwood
Username: Jonathan_f
GA USA
Post Number: 2220
Build quality. Not reliable. SQ and SPL isn't really impressive either. Since you said "subs", remember that one good sub is better than two cheap ones, consider your total budget and look into getting one sub that'll perform similarly or better than the two cheap ones. Most common thing I'd see in my shop is someone thinking they "need" two 10s or 12s in a sealed box, when really one better one (ported OR sealed) would do a better job than both of the others, with less power at that.
Arizona
Post Number: 73
they just are'nt, heard them at the audio shop, rip off also
