Subwoofer Wiring Help
Username: Deevolax
Salisbury, Maryland USA
I have two Audiobahn AW1000Q subs and two Audiobahn A8002T Amps and I need a way to wire each of the subs so that the amps see them each as 4 OHMs. I am going to be wiring each sub up to its own amp, so I need the wiring scheme to be specific to each sub and its paired amp. Any help would be awesome. Im out.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4475
only possible if each sub is single coil 4 ohm, or dual 2 ohm.
if your subs are dual 4 ohm coils each, you can't get a 4 ohm load to a bridged stereo amp.
ideal matches for a single sub and amp are:
mono amp and 2 ohm sub
mono amp and dual 4 ohm coil sub
stereo amp and 4 ohm sub
stereo amp and dual 2 ohm coil sub
any of these will yield full power from the amp.
Username: Boopers
Lima, Ohio United states
Post Number: 138
holy cow, welcome back Glasswolf!
