Sq and sql
Username: Colorblind_2004
Post Number: 33
I went to RE website to get some box specs, and it had to cubic ft. for SQ and SQL boxes what the hell is the difference between sq and sql? Is sql like spl? I just want to know which one will be louder...Thank you.
Username: Blindc1rca
Post Number: 178
I believe those are two types of boxes manufactured by RE, if you want specs for your sub look at the sub and press ts or tl i forget which one, t-something.
Username: Redskin
LondonEngland
Post Number: 82
SQ is purely for sound quality
SPL is purely for loudness
SQL is a mix of the two (in my opinion leaning more towards spl than sq)
