Sony CDX M360
Hi all,
Been tearing my hair out with a problem I have!! This head unit came with my Ford Galaxy (second hand). I have upgraded the unit in the galaxy now and want to install in my partners ford escort. I have plugged everything in using autoleads conversion loom and I have power but, Although the unit is on when the ignition is on I cannot use any buttons!!! None of them seems to work, I cannot close the front, change the volume or anything. When I insert a cd it plays fine but I cant do anything else!!! is the unit bust or is there a secret trick I have missed!!
All help gratefully received!!!
I want to die peacefully in my sleep like my grandad,
not screaming in terror like his passengers!!!
Username: Frammy
Toronto, Ontario Canada
if thats the one where the face folds over and the controls are hidden then it may be overheating. i had the same problem with that deck, nothing worked, i'd press the volume and the track would change, all kinds of weird crap. i got it rid of it and got an apline, but i was told that type is notorious for overheating.
