Great, good, bad, or ugly?
Justanimput
I'm checking out the following items, any imput would be great.
component
A
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5724270230
or
B
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5724521559
woofer
C
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5723763344
Username: Invain
Michigan United States
Post Number: 236
bad links
Username: Insearchofbass
Post Number: 828
All three links are good. I have not had any of these brands but i do know they are all good. This is one for jon to cover on the specifics.
Username: Jonathan_f
GA USA
Post Number: 2154
They are all in the great category. I'm really not that crazy about Nak's components personally, but that's just opinion. CDT Classics are great, a little better balanced than the Naks IMO, Naks are a little brighter on the high end. Oz also makes a great subwoofer. All of them are great, I'd personally get the CDT 3 ways over the Naks.
Username: Invain
Post Number: 241
Man, I don't know what's up with my net, but none of the links will work.
Justaninput
Joe, try to copy the item number at the end of the link and paste it on ebay search.
I was looking at the Perfect to start off, but found out it would take quit of bit of work on my car to fit those speakers and the tweeter is too harsh, so I'm going w/ different set. Stilling checking on the cdt set, but I don't they would let it go for any less than 300, willing to paid pro install for this set if I win. My buget for the component is around 200 or less.
I listen to r&B, soft rock, jazz, rave, techno. Any good suggestion for the component?
As for sub, I ordered a idmax, it's on the way(can't wait) lol. I was just wonder how is that oz sub compare to the idmax I'm getting?
thank
