atreyu rock Unregistered guest | im looking at 2 different 6.5 components, infiniti's KAPPA60.5CS or CDT's CL61 which one is a has better sq? or is there is a better 6.5 for around the same price |
Gold Member Username: Jonathan_fGA USA Post Number: 2027 Registered: May-04 | Personal preference really, I like the CDTs better. Warmer, softer set. Very good for the price. If you go the Infinity route, it's not too much more to get the KappaPerfects. Depends totally on your personal taste and budget, but all are great sets. |
New member Username: StanleycPost Number: 5 Registered: Oct-04 | How do the CDT's compare to the Dyns? In another thread, Dyns were also said to be warmer and softer and that is what I prefer. Also where can I get CDT's? |
Gold Member Username: Jonathan_fGA USA Post Number: 2028 Registered: May-04 | CDTs aren't as laid back, but still very accurate. The Classics wouldn't really compare as well to the Dyns as the HD and Eurosport CDTs would. CDTs are all over online, www.woofersetc.com has them. Dyns are not cheap speakers, but they're on that site as well if you want to do a price comparison. |
New member Username: StanleycPost Number: 8 Registered: Oct-04 | The CDT's seem like they are a lot cheaper, even the HD's and Eurosports. Are the Dyns worth the extra money? |
Gold Member Username: Jonathan_fGA USA Post Number: 2030 Registered: May-04 | The Eurosports are actually more expensive than the Dyns. It's all in your opinion. I like both, and think you should listen to them and formulate your own opinion. HDs are very nice and cheaper than the Dyns. Softer tweeter on the HDs compared to the Eurosports. Dynaudios are the softest still. |
