Ground Wire
Juggalo Jeff
I have a 4 guage power wire and an 8 guage ground. Will buying a 4 guage ground be a good thing to do and will it reduce any noise implemented in the system i have 2 subs.
Username: Boopers
Lima, Ohio United states
Post Number: 116
you should always have at least the same size ground as power wire, always
Juggalo Jeff
well i just have a schoshe wiring kit y is it that they give u a 4 guage power but 8 gauge ground?
Username: Jonathan_f
GA USA
Post Number: 2058
If you have excess cable left over, just use that. If not, just try to go to an audio shop and buy about a foot or two of it, won't be terribly expensive.
Juggalo Jeff
alright thanks
Username: Koz1031
Monticello, In United states
Post Number: 203
yeah radioshack has 4 for 97 cents a foot.
