Rca hookup
Username: Stefiny
Cincinnati, OH USA
I just bought a 1996 mercury sable with a factory stereo and I wanted to know if there is a serperate rca hookup I can buy to hook up my subs in this car because I do not want to change the factory stereo out, but I want my subs in the car.
nope
Username: Jonathan_f
GA USA
Post Number: 1888
You need to use a line out converter such as this one: http://www.crutchfield.com/S-bWtnt0sB4JJ/cgi-bin/ProdView.asp?i=101PL2&cc=01&sea rch=line+out+converter
This allows you to convert your head unit amplifier outs to RCA lines. Only option you have. I don't recommend splicing the lines to run speakers and the LOC together, however. Honestly, an aftermarket head unit with RCA preouts sounds a lot better. An LOC is prone to noise introduction into the system. If your head unit has high level inputs, you can just connect the rear channel speaker wires to the amp to get output.
Username: Noblemobile
Van Nuys, CA USA
Also knowen as a Hi-Low converter. Don't buy a cheap one to save money, but you do get what you pay for so be carefull.
Username: Forcesofchaos
Post Number: 56
hey jonathan could i do that with a lineout converter like connect it to rear speakers? and then bring it to amp?
thanks
