Little help on remote
Username: Bass_lover
Post Number: 7
My amplifier has a remote plug that looks exactly like a phone plug, I'm told it is for a seperate volume that makes the music louder, is it worth buying one? will it make a difference? or will the head unit take care of it all?
Username: Glasswolf
Post Number: 747
it's actually for a "bass boost" control that mounts up at the dash.
it's just an attenuation cut/boost circuit so if the bass is too much you can turn it down a bit at the amp.
if you need it, is up to you.
