Noob question
Username: Zex
Hi, if im hooking up 2 subs to one amp do i need a 2 channal amp or what? Thx
Username: Pat_l
Tucson, AZ USA
Post Number: 604
No, you could use any amp you want. I would say to get a Mono channel amp, so that way you could run the two sub in paralell. Or get a two channel.
Username: Zex
ok and do i divide the RMS rating by 2 if its a mono amp to see how much power each sub will be getting?
Username: Jmloughrey
Farmington, CT
Post Number: 362
yes
Username: Skema
Manch, NH US
Post Number: 32
what does it mean to run subs in parallel.
How would the RMS change if you ran two subs off one amp in parallel?
Username: Comet345
Orlando, FL USA
Post Number: 48
yeah, i would like to know as well ...
if you have 500 watt amp, like a JL 500/1, and you have two subwoofers that require 500rms each... if you hook these two subs up to the amp does each sub get 250w or 500w? I know that wiring in series or parallel changes the impedence, but does one wiring option change the amount of wattage a sub would receive? Can someone explain this a little more in-depth? I've looked online but havnt found much of an in-depth explanation (I've found wiring diagrams and such, but none on the asked question above)
Username: Comet345
Orlando, FL USA
Post Number: 49
