Kicker KX1200.1 Vs. Rockford T1000bd
Okay, for those of you who don't know I have 2 T1's and I was wandering whether the KX1200.1 or T1000bd, both mono amps, would be better? On the one hand the T1000bd is the same name brand, but the KX1200.1 better matches the rms of the 2 T1's (600 RMS ea.). i can get the KX cheaper too here.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5722357081 %26
I don't know how to insert hyperlinks here so i'm afraid you'll have to copy & paste. Can anyone help? Jonathan?
Username: Comet345
Orlando, FL USA
Post Number: 50
I am thinking about getting the kx1200.1 ... orion 1200D is same power, but hundred bucks cheaper, but I think I might go with the kicker amp if I end up getting some kicker subs
