Car audio batteries
Username: Boopers
Lima, Ohio United states
Post Number: 181
yeah, the other day I was at a car audio shop getting ideas for my car. they told me about this car audio battery that is 1200 cca and puts out 14.4v. I can't remember what the brand was and they were quoting 199.99 for it. Can't seem to find it anywhere. If someone knows the brand *not optima btw* would love it if you could let me know. Thanks.
Username: Sancho886
El Cajon, CA US
Post Number: 24
might be stinger
Username: Sancho886
El Cajon, CA US
Post Number: 25
http://www.stingerelectronics.com/web/prods/batteries.asp
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 4806
don't bother with a battery putting out more than 12.5 volts unless you have a high output alternator.
The alternator has to put out a higher voltage than the battery to charge it, and anything over about 15 volts could damage electrical components in the car.
stick to 12 volt batteries and 13-14 volt alternators.
