Best 12" subwoofer? Only pushing 300 watts?
Username: Stamant
Pensacola, FL USA
I am looking for a 12" sub for my Tahoe. I have a PPI-2150 amp rated at 1x300W or 2x150W. I have no limit as far as a budget. I just want the best sounding sub with only 300W to push it. Can anyone give me advice?
matt77
cerwin vega V-max 12" is 300 rms
Username: A3forme
Post Number: 298
You could also look at the Ifinity Perfect 12.1 or JL W3v2. Depends on the sound you're looking for. You want SPL or SQ?
Username: Hiphopanonymous
Post Number: 131
type r, infinity perfect, kicker, JL, or cerwin vega.
Username: Stamant
Pensacola, FL USA
I am looking for a sub with great sound quality while at the same time can rattle my windows. Thanks for everyones help.
Username: Ctx
Post Number: 63
maybe an adire shiva with a large ported box
Username: Jonathan_f
GA USA
Post Number: 1918
If you have no budget, why don't you just put that amp on components, then buy a sub and amp w/ more power? Just my opinion, and you're more likely to find one that'll rattle windows.
