Bronze Member Username: Dean_kRegina, SK Canada Post Number: 30 Registered: Jun-04 | Okay, I have never worked with plexiglass before. Can anyone tell me, or point me to a site showing me where I can buy the needed supplies, and show me how to actually make a mold etc.. thanks! |
djhobo9 Unregistered guest | do you mean fiberglass? i've worked with plexi and don't know what you mean by mold.... you usually buy plexi in sheets |
Silver Member Username: Koz1031Monticello, In United states Post Number: 160 Registered: Jul-04 | Just what are you planning on doing? I've worked with plexi alot and can't say there are any special tools needed. If you are planning on doing any bending then is when it gets tricky. As you need to heat it first. The best way to do it is in a oven at about 375 degrees. but you have to keep an eye on it, or you'll burn it up. You may want to look at lexan or polycarb instead. It is more flexible as plexi is actually a little denser and has a tendency to crack or break. In all actuality you would be better off finding a place that can do the work for you, as none of this stuff is that cheap. |
djhobo9 Unregistered guest | great site for polycarb cheap.... www.mcmaster.com just do a search for 'polycarbonate' |
