CHEAP help!
that guy
hey all im lookking at spending about 250$ for a amp/sub/box ...any suggestions...im thinking one shiva and a jbl600.1 ...somebody tell me other options. thanks!
Username: Chevy_for_life
Post Number: 7
if you do that build ur own box! lot cheaper
Username: Symplestiles
Stockton, CA Usa
Post Number: 190
you cant get that amp and that sub for $250.. the sub alone will run 125 and the amp at its cheapest would be about 230..save some more cash before you buy anything. dont rush into buying a system when your strapped for cash, youll end up getting cheap equipment that will die on ya in a heartbeat..as far as the shiva and JBL go though, those are an awesome combonation.
Username: Jamesdunn
Post Number: 20
Its Called Ebay. To find what u need.
Post Number: 10
Yo man you aint gotta hatein..Not everyone likes used products.. specially if you dont know where they've been!!
