What do I get dual 2 ohms or dual 4 ohms for subs?
Username: Macdizzlez
Massachusetts
I'm not familiar with car audio so, which one do I get?
Username: Insearchofbass
Post Number: 734
depends on the ohms the amplifier can be bridged to
Username: Sqman
Midhurst, Ontario Canada
Post Number: 11
depends on your amplifier and how many subs you are going to run. Dual 2 ohm is usually prefered for a single sub set up, dual 4 ohm being prefered for a multiple sub set up. most amps can see 4 ohm bridged and 2 ohm stereo, mono amps can see lower.
Username: Sqman
Post Number: 12
shane mcgovern....that name sounds framiliar, did you used to live in ontario?
