Please Help!!!!!
Will a JL 1000/1 be able to push two 12w7? Or should i just get two JL 500/1?
Please Help!!!!
Username: Fishy
Tamarac, FL USA
Post Number: 170
They'd probably sound almost exactly the same with a slight edge to the twin 500/1's. I think they are a little more "underated" and would probably have a little better damping factor running at a higher impedance, but with the JL's switching voltage rails I'm not sure.
Jonathan would know for sure of course.
Has anyone thought "alternator" yet?
-Fishy :P
Username: Jonathan_f
GA USA
Post Number: 1799
Better the single 1000/1 IMO. You'd have to match the gains of the dual 500/1s perfectly for best SQ, which is very hard to do since each amp/sub will be a little different due to tolerances. Damping difference wouldn't really be noticeable, or worth mentioning for that matter. Think of the JL regulated amps more as 1.5 ohm stable amps capable of putting more power into higher impedances instead of amps that don't add power with less impedance. Difference of the amps at different impedances isn't a lot. Plus, the 1000/1 will be cheaper and take up less space, and won't require a distribution block and two ground points.
Thanks Fishy and Jonathan is there any other amp that will push does sub's.
Username: Fishy
Tamarac, FL USA
Post Number: 172
Jonathan knows.
-Fishy :P
Jonathan is there any other amp that will push does sub's?
GA USA
Post Number: 1812
Yeah, any amp that'll do about 1500W RMS into 1.5 ohms. Depends totally on your budget. JBL 1200.1 would work.
Jonathan what about a PD3 amp!!!
GA USA
Post Number: 1820
Which amps are you talking about there? You're not talking about the Boss PD-3000 amps are you?
My bad i was talking about a Phd2....
2000 W x 1 into 4 ohms
2000 W x 1 into 2 ohms
1000 W x 1 into 4 ohms
Mono block - single channel amplifier
OR the EARTHQUAKE PH-D3
~5000 Watts Maximum Power
~3000 Watts x 1 into 1 ohm
~2600 Watts x 1 into 2 ohm
~1300 Watts x 1 into 4 ohm
