Subs with a shallow mounting depth???
hi.
i have a 4 door nissan frontier and i wanna put some subs in it.
i have some room behind the back seat that i can build a box to fit, but i would need some shallow mount depth subs to do it.
the box would only be able to hold a sub w/ a mounting depth of about 5" max.
are there some decent 10" out there that will fit in that small of a space? (only wanna spend bout $120 per sub, will spend more if i HAVE to)
Juggalo Jeff
Yea for sure check out the pioneer premier sub at pioneers website i have the link but it doesnt work on here for some reason. Its not a 10 tho the sub has a mounting depth of 4" so it should be adequate. The model number is TS-SW124D
Username: Symplestiles
Stockton, CA Usa
Post Number: 177
look at RE 8" subs. http://reaudio.com/flash_index.html cant imagine they have a depth deeper than 5" but email the customer service department and get the subs specs
Username: Sploosh56
Post Number: 405
2076_4061_90400838%2C00.html,http://www.pioneerelectronics.com/pna/product/detai l/0,,2076_4061_90400838,00.html
Username: Koz1031
Monticello, In United states
Post Number: 151
http://www.earthquakesound.com/SWS04.htm
Username: Fishy
Tamarac, FL USA
Post Number: 177
Wow, those things look like frisbees.
Crazy shallow mounting depth, but how do they sound?
-Fishy
Username: Wrestlertreece
Post Number: 105
Thats one expensive frisbee Fishy...U got the money to get em.. and i'll play..LOL :-)
i like those earthquakes, but are they any good?
also is that 1.75" excursion the linear xmax???!!! or xmech?
where can i get a pair of the 12" earthquakes...that is if they are any good.
