12" DVC HIGH-PERFORMANCE SUBWOOFER
chesserabbit
hey what would be an good amp to put on these subs http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=299-660
Im thinking about getting 2 of them.I have a price range from $200.00 to about $375.00 for an amp thanks.
Username: Invain
Michigan United States
Post Number: 146
I would find out what the brand name is first.
chesserabbit
ok i see can i find out.
chesserabbit
i think its dayton audio
Username: A3forme
Post Number: 166
No, it's Kove Armegedon.
Username: A3forme
Post Number: 169
BTW, it's a killer sub for the price. They are not seconds. They just had like extra components left over and decided to sell them to Parts Express unbranded. They are exactly the same as the pretty one with the etched logo in on the magnet and the spiffy cone. Usually go for abot $400 a piece. A steal at $169 IMO.
chesserabbit
thanks so what would be a good amp to run 2 of them.
Username: A3forme
Post Number: 175
You could use a Kicker KX1200.1 that puts out about 1400w RMS @1ohm (they're underrated). You could try the Phoenix Gold Xenon X1200.1 It puts out 1200W at 1-4ohms. (like the JL 1000/1)
You could also use the Hifonics BX15001D. All shoud do the job.
chesserabbit
Thanks MazdaMan I think I go with the Hifonics BX15001D amp thanks again.
