What glue
Username: Boopers
Lima, Ohio United states
Post Number: 84
my voice coil seperated from my cone, what is the glue that is used to hold the coil and cone together and where can I get it
Username: Zacdavis~
Post Number: 27
goto your local bodyshop supply store and buy some high heat urethene, or epoxy, get quick set because it tends not to be overly brittle, but can't you return it for warranty, that sounds like a factory defect to me!
Username: Boopers
Post Number: 85
it's a hand made speaker, so it wouldn't be a factory defect, and since it just needs reglued I don't see the point in going and paying to have it done
Username: Boopers
Post Number: 86
also, how would I remove the dustcap without destroying it so that I can reglue the coil to the cone
