New member Username: Poolplayerpro3Clayton, Nc Usa Post Number: 1 Registered: Jan-10 | i have a durabrand ht-3915 system and it only gives sound from center and rear speakers. I have changed speakers and fuses but nothing works...please help |
Silver Member Username: JrbayLivonia [Detroit area], Michigan USA Post Number: 997 Registered: Feb-08 | Greetings Chris, What are you listening to as far as the media (a DVD movie for example)? Depending on what you are listening to there may not be much sound information going to those speakers. If that is not the case put the unit in Stereo mode (if possible) and see what happens. |
New member Username: UrbaninjamattPost Number: 1 Registered: May-16 | I m in need of an awnser i cannot find anywhere. I have a durabrand ht3915 and the left surround channel is really scratchy and a lower volume from the right surround channel. Any negative side works with any combination of the positive side and sounds fine with the exception of the positive left surround channel. Any feedback would be awesome thanks. |
New member Username: ZeanwebsterPhoenix, AZ United States Post Number: 1 Registered: Sep-18 | The most sound comes from the center speaker only, with ambient sounds coming from the rest of the speakers. As the action on the screen gets more complicated, such as explosions, crowds, etc... or when the music soundtrack becomes more a part of the film, you will notice more sound coming from the side and/or rear speakers. Source: https://www.lifewire.com/home-theater-troubleshooting-tips-1846787 https://www.audioreputation.com/best-wireless-surround-sound-systems/ |
