Sony home theater
Username: Jay228
Windsor, Ontario Canada
Post Number: 63
I am planning on buying a home theater.. i am having difficulty choosing a system.. ive come across these two home theater systems but i dont know which one to buy.. plz give me suggestions
http://www.bestbuy.com/site/Sony+-+1000W+5.1-Ch.+3D/Wi-Fi+Blu-ray+Home+Theater+S ystem/2024262.p?id=1218305999131&skuId=2024262
http://www.bestbuy.ca/en-CA/product/sony-sony-1000-watt-5-1-channel-3d-blu-ray-h ome-theatre-system-bdve880-bdve880/10169502.aspx?path=cc735021a5514ea2a291b4b547 d17317en02
thx
Username: Vm8444
TorontoCanada
Post Number: 418
hi jay I dont like sony
how about denon.
1611 reciever or 1911 from amazon.
with energy take classic 5.1
speakers from amazon.
Username: Adenoaddison
No doubt Sony is one of the best Home Theater system Manufacturing Company but apart from it, there are several companies which manufacture Home Theater. Get the best home theater or if you have no idea about it then make online home theater system review and choose one of them which suits you most and comes in your budget. It is Compatible with all high resolution movie formats like Dolby True HD and DTS HD.
Username: Project6
Post Number: 15892
Sony is one of the best HT System Manufacturing Company? I don't think so.
Username: Einteractive
I would say that if you are buying a Sony home theater then you won't regret, as its one of the best brand in electronics media, especially home theater system.
Need to Register?
Forgot Password?
Enable HTML code in message
