Blu ray video run through AVR or not.
Username: Diggytooth8
Post Number: 19
I have a Marantz 6005 AVR. I was wondering if it is worth the extra $ to buy a Blu ray player with dual HDMI outputs so i don't have to run video through my AVR. I can use one for audio and one for video directly to the TV.
Thoughts?
Username: Nutpi
HDMI is the convenience and give you better sound and picture quality. I have my entire home theater connection using HDMI cables.
Username: Vm8444
TorontoCanada
Post Number: 414
yes just one hdmi into reciever
then one hdmi out to tv
Username: John_s
Columbus, Ohio US
Post Number: 2803
I believe the 6005, like the previous model 6004, has direct passthrough for HDMI in to HDMI out. There is no reason to suspect any signal loss with any high quality digital video signal going through the receiver via HDMI. I would not, however, rely on this receiver to adequately convert any high quality analog component signal to HDMI. In that case, I would run component video directly to the TV, bypassing the receiver entirely.
Post Number: 24
Thank you.
I haven't purchasd the Blu ray yet. Is the video signal from a blu ray, via a hdmi, digital or analog? I presumed it is digital. If so, it sounds like your advice is to run 1 hdmi to the AVR, then 1 HDMI to the tv, which has hdmi ports by the way.
Thanks John.
Post Number: 25
I think I understand running a signal out of the component out on the blu ray is analog, and going out of the hdmi is digital. You choose which one to use depending on the quality of the signals i.e. how good the blu ray player is.
Username: John_s
Columbus, Ohio US
Post Number: 2804
HDMI signals are digital including both video and audio signals.
quote:
If so, it sounds like your advice is to run 1 hdmi to the AVR, then 1 HDMI to the tv, which is a domestic, which has hdmi ports by the way.
Yes, as vince mirabelli's post recommends above.
I think you understand running a signal out of the component out on the blu ray is analog, and going out of the hdmi is digital. You choose which one to use depending on the quality of the signals i.e. how good the blu ray player is.R/}
For Blu-ray movies, the only output/input to use is HDMI. }
Post Number: 26
Thanks John, I appreciate it.
Need to Register?
Forgot Password?
Enable HTML code in message
